Mazda Xedos 6 CA KLZE '94 White...
Yep I changed rear brakes too. They fit P&P, the only thing you have to do is mount them on opposite sides, I mean right caliper goes to left wheel, left goes to the right. Youll also need longer parking brake line, Im about to order one as a special order.
Absorbers fit almost P&P, i only had to retrieve the mountilg balls from my old absorbers. But if you get new balls you doont have to do that
- Od: 22 lut 2009, 12:42
- Auto: Xedos 6 KLZE
Xedos 6 KF 99r
Thanks a lot. Parking break cable that you ordered it is from mps 6 or another model? Do you have found new or second mps 6 front/rear break callipers? In Romania i couldnt find mazda mps 6 break calliper on second hand i i guess that new oem are expensive. That are some aftermarket mazda 6 mps break callipers? Do i have to change that piece(servo breaking pomp fluid) from xedos 9 like you did?
Does it worth that upgrade? The breaking is a lot better than with the xedos breaks? I like the looks too:)
Thanks and sorry for my bad english. I like your xedos 6 and your work. Great job!
- Od: 21 lis 2010, 09:15
- Auto: mazda xedos 6 2.0 v6 1997
I think that mounting brake set from Mazda 6 MPS (like Seturitus did) is modification only for weirdos (in positive way of course
). Purchasing this parts in good price is almost impossible and what is more, MPS brake set' efficiency is not much better (in everyday use) than in brake set from regular Mazda 6. So if you are not a racing driver or highway menace (PIRATE
) you will not probably appreciate mounitng MPS brakes. What is more, the MPS brakes' look is incredible!
I've bought front brake set from mazda 6 in good price and I'm about to mount it (with servo from Xedos 9). Many users of Xedos 6 and 626 say that it is very good solution because of poor efficiency of Xedos 6 and 626's brakes.
All in all, if you are looking for improving safety (better efficiency of brakes), try to purchase the set from Mazda 6 (set from GY or diesels probably – the braking discs were bigger in this versions). I think (after reading this forum users' opinions) that such modification can be satisfying for you .
But if bigger costs are not big problem for you, you can follow Seturitus in this mod
Z nowości kupiona kierownica od Xedosa 9, ma poduszkę z ładnym logo Mazdy do tego niepowycierane przyciski tempomatu, które swoją drogą pracują przyjemniej niż w X6, tzn jest wyczuwalne i słyszalne kliknięcie przycisku, w przyciskach od Xedosa 6 tego nie ma
Kierownica tak czy owak poleci do obszycia razem z gałką biegów, ale warto było ją kupić dla poduchy
Xedos 6 KF 99r
A wielkość ? Taka sama ?
Osobiście szukałem do siebie NARDI TORINO z BJki lub MX5
- Od: 5 gru 2013, 19:11
- Auto: Xedos 6 ®isto ©oncept, Mazda 323F 2,0 '01 ,
SIMSON SR 2 '59r ,
Suzuki GR650 '83r
Bashan 250 – skradziony,
Colt '99 1,3,
TDM 850 '01
Tak wielkość taka sama tylko wydaje mi sie że ta z X9 ma troche grubszą, przyjemniejszą obręcz.
Dałem za nią 130zł. Ale obręcz jest zniszczona bardziej niż myślałem więc tak czy owak pójdzie do obszycia.
I do tego jest z auta palacza więc śmierdzi
trzeba obowiązkowo zmienić obszycie.
Xedos 6 KF 99r
Cena dość przyzwoita, pod warunkiem że obszycie nie będzie zbyt drogie. Sam Obszywasz czy Oddajesz gdzieś
SIMSON SR 2 '59r ,
Suzuki GR650 '83r
Colt '99 1,3,
TDM 850 '01
Oddaje, w zakładach robią to za ok 150zł plus do tego obszyję sobie gałkę, powinno sie w 200 wszystko zmieścić
Grunt żeby cieszyło oko
Xedos 6 KF 99r
Można trochę taniej ( 38PLN, 2,5h roboty przy 4 piwkach
Efekt trochę mniej spektakularny ale jednak:
SIMSON SR 2 '59r ,
Suzuki GR650 '83r
Colt '99 1,3,
TDM 850 '01
Risto podeślij linka z tym pokrowcem bo całkiem ładnie to wygląda:)
Dopisano 10 lut 2015 19:27:
Piwko mam zawsze , małżonkę szwaczkę , więc już bliżej jak dalej do ładnej kierownicy:)
- Od: 6 gru 2009, 11:35
Xedos 9 TA KL 99 r. LPG :)
Poszło PW żeby nie śmiecić.
SIMSON SR 2 '59r ,
Suzuki GR650 '83r
Colt '99 1,3,
TDM 850 '01
Wiem,obszyłem tak 90cm rączki od wózkaristo77 napisał(a):Można trochę taniej ( 38PLN, 2,5h roboty przy 4 piwkach)
- Od: 8 wrz 2006, 15:22
- Auto: Mazda 6gh 2.5pb
Chodzi mi od paru tygodni po głowie pomysł przemalowania lusterek na biało-czarno. Lusterka już rozebrane, przy okazji usunąłem bąble korozyjne, miejsca te potem wyszpachluje, będą jak nowe
Efekt końcowy za pare dni.
Wleciał też nowy rejestrator. Nie wiem po co bo stary był dobry, ale ten nagrywa w HD więc sie skusiłem :p
Dopisano 12 lut 2015 18:15:
Spy photo z malowania lusterek
Pomysł żywcem zerżnięty z 6 MPS
Xedos 6 KF 99r
Lusterka pomalowane i założone na auto. Wyglądają bardzo przyzwoicie, tak jak mówiłem pomysł zerżnięty z 6 MPS
Xedos 6 KF 99r
Keeper of the Art
- Od: 22 kwi 2012, 17:06
- Auto: Xedos 6 KF 98' – Sprzedany
Xedos 9 KJ 97' – Sprzedany
200SX SR20DET 89'
Apropos kierownicy, sam zmieniałem poduchę na tą z X9, bo już nie mogłem na tą padakę jaka była w X6 przed liftem
I to lśniące logo Mazdy cieszy oko
- Od: 13 mar 2011, 00:10
- Auto: Xedos 6 CA KF 2.0 V6 automat
