Ja troche bardziej maniak mocnego bassu, narazie piec klasa AB Steg K2.04 głośnik Orion Hcca 12.4
Viba na suba masz klase D czy AB ? drzwi głuszyłeś ?
www.mazdaspeed.pl
mlody1921 napisał(a):Viba na suba masz klase D czy AB ? drzwi głuszyłeś ?
VIBE Technologies once again brings an industry first, the stunning new BlackBox range of Class GH BASS amplifiers.
Class G operation involves changing the power supply voltage from a lower level to a higher level when larger output swings are required. This involves a single class AB output stage that is connected to two power supply rails by a diode, or a transistor switch. The design is such that for most music, the output stage is connected to the lower supply voltage, and automatically switches to the higher rails for large signal peaks. Using two power supplies improves efficiency enough to allow significantly more power when compared to traditional Class AB or Class D amplifiers. Class G technology is becoming more common in professional recording studios.
Class H operation takes the class G design one step further and actually modulates the higher power supply voltage by the input signal. This allows the power supply to track the audio input and provide just enough voltage for optimum operation of the output devices.
VIBE DEEP SPACE™ BASS HYBRID Class GH amplifiers combine the best of both of these new technologies to produce an amplifier that has all the efficiency benefits of a Class D amplifier with the smooth sound of a Class AB amplifier.
What does all this techno jargon actually mean? Simple, sound quality that blows away Class D amplifiers combined with 73% efficiency compared to 50% efficiency of Class AB. So we have the efficiency of Class D amplifiers and the sound quality of Class AB amplifiers.
mlody1921 napisał(a):Orion Hcca 12.4
Użytkownicy przeglądający ten dział: Majestic-12 [Bot] i 3 gości
