toolboy napisał(a):niedlugo adapter Sohn'a i problem z glowy
A cóż to ten "adapter Sohn'a"?
www.mazdaspeed.pl
nismo napisał(a):toolboy napisał(a):niedlugo adapter Sohn'a i problem z glowy
toolboy napisał(a):nismo napisał(a):toolboy napisał(a):niedlugo adapter Sohn'a i problem z glowy
zmienia zrodlo oleju dla pompy podajacej olej do komory silnika, instalujesz zbiornik z olejem dla dwusuwow. Cos co powinno byc w tym aucie fabrycznie ale Mazda uproscila sprawe,
bo przecietny Kowalski moglby nie ogarnac
http://www.rotaryaviation.com/oil_injec ... aptors.htm
http://www.rotaryinsider.com/diy-tac38/ ... -gap28.htm
The point of this adapter, is to stop using engine oil to lubricate the apex seals in your rotary engine. This is a good thing because:
1. Your engine will no longer burn oil from the engine
2. Your seals can be given fresh oil that isn't dirty
3. You can feed your seals 2 stroke oil, which is meant to be burned.
4. If you're a firm believer that you can't use synthetic oil because it's bad for the seals, using synthetic oil will no longer an issue because your motor oil isn't being used for seal lubrication!
