Nawigacje – opinie i porady
czyli ile wynieisie mniej wiecej taki zestaw jaki teraz skladacie? czytasz z wielka uwaga to co robicie i sie zastanawiam czy jest sens sie tak bawic bo nawet nie ma pewnosci ze to dziala Ani serwisu ani gwarancji Czy cena to rekompensuuje? czekam na info
fifun
to co na fotkach to oryginal
to co na eby to mozliwosc
czy ktos byl juz w ukrytych ocjach nav
ja ide probowc
monitor idzie po rgb wiec zwyklego kompa da sie podlaczyc
Here are the wire listings, match them to the posted diagrams a few pages back if you need the reference.
2X= Video (RED)
2W= –
2V= Video (Green)
2U= Video GROUND
2T= Video (YELLOW)
2S= –
2R= Video (composite sync) *** (WHITE)
2Q= Shield GROUND
2P= Monitor serial output
2O= Shield GROUND
2N= Monitor serial input
I'll help with what I can when I get back from Vegas. Oscar FTW!
Panasonic makes the screen. Denso makes the brain unit. Navteq makes the DVDs.
Until then.
Hidden Menu #1
Turn ignition to ACC.
Select Menu on the controller.
Select Navigation Set Up
Select Calibration
Select Map Version
Press Up 2x and Down 2x.
Hidden Menu #2
With everything in the OFF position:
-Turn key to ACC.
-Wait for Nav to go to "Agree" screen.
-Hold and continue to hold the "return" key on the Nav remote.
-Turn the parking lights on and off three times, and let go of "return" button.
ja ide probowc
2X= Video (RED)
2W= –
2V= Video (Green)
2U= Video GROUND
2T= Video (YELLOW)
2S= –
2Q= Shield GROUND
2O= Shield GROUND
Until then.
Hidden Menu #1
Select Calibration
Select Map Version
Hidden Menu #2
-Turn key to ACC.
- Od: 3 cze 2009, 20:10
This article disappeared from my site for a while.. restoring..
The DENSO NAV system uses a DVD which you can find in a Prius so equipped by sliding the driver seat forward, prying off the plastic cover panel, sliding the eject button lock over, and hitting the eject button while the car is in aux power but not yet “On”.
If you put the DVD in your home computer, you will see an ISO9660 filesystem representation of the KIWI data files used by the NAV computer. Check out the KIWI Documents for the actual data format of these files; I’m actively trying to write something to decode them now. Mapmaster appears to be Toyota’s navigation division.
This is a full 8G DVD, you will need a dual-layer burner to make a copy.
The files are just pointers into the actual KIWI datasets.
VERSION.TXT – The version of the data on this DVD (ver.04.2 for a DENSO NAV 4.2 DVD)
ALLDATA.KWI – A file that represents all of the KIWI MAP data (I think). – This is the biggest file on the root of the filesystem at 2.8G
COVERAGE.TXT – Text file listing all files in the COVERAGE/ directory
COVERAGE/ – Directory full of BMP images showing the coverage area of this DVD as a raster image. This would be the easiest thing to hack with your own graphics.
INDEXDAT.KWI – Lists the IDX/ directory files.
IDX/ – Directory full if Index files. My guess is for searching and/or quick access for names/addresses/phonenumbers etc, as that is what they appear to contain. – This is the biggest directory on the DVD (5G)
METADATA.KWI – Metadata. Contains this string:
LANG::=US English,UK English,German,French,Spanish,Italian,Dutch,Swedish,Danish ; CHCD ::=ISO 8859-1 ; COOR::=WGS84 ;
SPEC.KWI – Specification file. Contains this string:
SUPERMETA::=AFUS:2.47, AGUS:2.47 ;
LOADING.KWI – Loading Module Management File. – At 520M, including strings like “/HDD/slot1/passwd.osg”, the first thing that I think of when I see this file is “this is the code that the NAV computer boots”. – “I Agree” is in this file. Removing that initial nag screen may be as simple as a binary patch to this file! Woo!
DICVCE56.KWI – From the strings, it looks like a group list of Points of Interest (not the actual points, just the general groups). This is a small file.
VIRTUAL0.DAT VIRTUAL1.DAT – No idea what these are for. They appear to be full of NULLs.
I’ll be updating this node as I figure things out.
I’ve created a quick little perl script based solely on the KIWI “All Data Management Frame” document 0500122e.pdf. The script, alldata.pl is a very rudimentary parser of the data structures, based entirely on a hash tree of the schema information gleaned from this document. Hey, it’s a start.
Update: KAMIYA Satosi has restored his Ruby KIWI Voice scripts
Mazda 60000 3500 litra wodoru + LPG + ON
Witam! Prosze o podanie adresu gdzie można wgrać polską mapę do mzdy 6. Posiadam mapę ale jest tylko europa zachodnia. Pozdrawiam
tadq
tadq – witamy
Może warto jednak poczytać ten wątek a nie śmiecić niepotrzebnie??
Szybciej byś otrzymał odpowiedź gdybyś sam poczytał
Paweledi, spadles mi z nieba. Juz dawno chcialem podpiac sie pod Navi tym RGB – udalo CI sie? Daj linki do materialow skad to wygrzebales? (ja robie car laptopa, wiec jak cos to mozemy sie zgadac – w koncu z tego samego miasta...
car computer robisie na
Płyta via atom itd ( ebay grosze lub allegro tylko nie oczekuj wiele procek od 900 do 1.6 a karta graficzna do d....py ) bo mała płyta 16 cm x 16 cm
tylko uwaga jest tego duzo musi być sata
Drogi jest do tego modół zasilania też ebay
obudowa jest taka jak nasze nav
do tego monitorka można dokupić folje dotykową i juz nie potrzeba myszy
a mam program który zamienia winde w car audio ( projekt free ) albo mialem jak rozwalilem system to moze poszło do diabla
modół CF pod ide mniej pradu ( tylko nie wiem ile wytrzyma karta CF windows no i musi miec do 4 do 16 gb ceny nie są straszne (xp cały czas na niej pracuje
a tak na marginesie wiem ze to nie ten wątek ale zrobiłęm dzisiaj 1010 km i moje stwierdzenie jest takie
1. nie gon madzi bo madzia tego nie lubi
2. nie lej jej do pełna bo jej cieżko ( połowa starczy a efekt będzie widoczny )
xp musi byc z sp2 bo sie nie zainstaluje ( mam takie cacko i pewnie kiedys wsadze do madzi jak to mowią inni )
daj meila na prv to ci wysle co ostatnio sciagnolem do nav i rgb
lub wyslij na
p.m@brodno.trzepak.net
jak przyjdzie mi mediaplayer z honk kongu i podlacze to pod monitro to dam znac
to co sie doczytalem to denso instalowalo to na linuxie lub winodows ce ale pewnie winda jest w tych dotykowych bo linxa dotykowego jeszcze nie widziałem
a wkurza mnie mala funkcjonalnosc tego cacka
lub wyslij na
Ostatnio edytowano 9 cze 2009, 14:15 przez paweledi, łącznie edytowano 1 raz
aaaaaaaaaaaaa i do tego jeszcze
usb radio
usb nav
można dodać play usb net i to już chyba wypas
i już masz wszystko
tylko czy to sie opłaca lepiej jest sobie kupić dotykowe 2 din i bez pierdzielenia sie to ma
od 350 do 900 $ honk kong + plus clo i podatek
brak tylko neta a koszt bedzie wyższy o 50 % pewnie tylko nie pytaj od któej ceny bo nie pamietam cen z ebay
usb radio
usb nav
i już masz wszystko
jutro pruje nav i zobaczę co tam wsadzili i czy się da upgrade jakie do tego wykombinować z uwagi na szybki start pewnie linx tylko dzie zapisany mam kolesia który jest maniakiem linxa jak by się dało wygrzebać z tego cacka to może coś by mi poradził
manika – czytak informatykiem praktykiem od linkxa i innych różnych takich
ale krzychu cos powinien wiedzieć na ten temat
a czywiecie że ta nav ma też możliwość sterowania głosem
jest gniazdo z tyłu a w opcjach menu #1 jest test tylko nie aktywny i dlaczego
czy brak softu czy mikrofonu musi być wykryty
śmieszne
MOZEMY sie spotkac brodno czwartek po 18. 19 . ale jeszcze nie będę miał playera bo idzie gdzieś 1 do 2 tygodnie
no chyba że będę miał czas podłączyć kompa
a pozatym muszę się podłączyć pod obdII już próbowałem ale mi nie wyszło bo przeście z usb na rs i rs do obdII pewnie sie nie dogadało
teraz musze spróbować rs---> do obeII
http://cgi.ebay.com/Mini-ITX-Carputer-C ... 7C294%3A50
http://cgi.ebay.com/Car-PC-Intel-D945GC ... 7C294%3A50
http://cgi.ebay.com/New-Mini-Bluetooth- ... 7C294%3A50
http://cgi.ebay.com/Car-PC-D945GCLF2-Vo ... 7C294%3A50
do tego monito lliput lub inny taki tylko trzeba patrzeć na rodzielczości obslugiwane
Jak kupujesz robisz to na własne ryzyko
