MX-3 1.6 TURBO
Postprzez armandask » 14 maja 2009, 07:00
Helow,
in our mx-3 club we have a mx-3 1.6 turbo project (GTX). Now main problems are with stock ecu... Do anybody know what to do with it?
some pics:
http://forum.mx-3.lt/viewtopic.php?f=20&t=1269&start=60
Thanks.
°Mazda mx-3 1.8 V6 24v 98kw°–> Sold
°Ford Puma 1,7 I4 16v 92kW°–> mamycar
°Mazda MX-3 KLZE 2.5 V6 24v 149 kW°–> Daily
Od: 13 kwi 2009, 09:43
Auto: mx-3
Postprzez Pit » 14 maja 2009, 09:03
armandask napisał(a):... main problems are with stock ecu
Please try to explain us those problems.
Od: 14 lut 2005, 06:56
Auto: FD3S
Postprzez Fiveopac » 14 maja 2009, 09:32
Throw away ecu. Install megasquirt :)
Less roof, more fun
CUP 2017 miejsce 3
CUP 2018 miejsce 3
Od: 25 kwi 2005, 20:07
Auto: MX5 NC 2.5T
RX8 R3
Postprzez armandask » 14 maja 2009, 11:19
The fuel mixture too rich and too lean, depends on RPM's
Auto: mx-3
Postprzez Pit » 14 maja 2009, 11:31
armandask napisał(a):The fuel mixture too rich and too lean, depends on RPM's
You can use FMU at this moment, and correct AFR with some kind of piggy-back. But, the best way for you will be...
Fiveopac napisał(a):Throw away ecu. Install megasquirt :)
Auto: FD3S
Postprzez Quaki » 14 maja 2009, 11:42
Did you change the injectors or the pressure on the fuel rail if yes it is normal problem there are 3 ways to resolve your problem
1. remapping orginal ecu
2.piggyback
3. stand alone like mentioned by Fiveopac megasquirt
Bets regards
2,5 v6 czarny
2.2 F2T czerwony
Od: 20 lip 2005, 14:02
Auto: Ford probe 2,5 V6
Ford probe F2T turbo + nitro
Postprzez armandask » 14 maja 2009, 13:09
Quaki napisał(a):Did you change the injectors or the pressure on the fuel rail if yes it is normal problem there are 3 ways to resolve your problem
2.piggyback
Bets regards
Injectors are GTX
Fuel pomp stock mx-3 (1,6 dohc)
About remapping stock ecu... Do you have that binnary file? :) (like i did with my klze)
Auto: mx-3
Postprzez Quaki » 14 maja 2009, 14:24
So you have stock ecu from ? GTX or from mx-3 (from what engine you have ecu)
I,m afraid that is not so simple like with the kl engine you if you want to remapp yor ecu you will have to do it yourself by chnaging the code of this ecu (or find someone who is able to do this and have hardware to do this)
Beszt regards
2,5 v6 czarny
2.2 F2T czerwony
Postprzez jackkpl » 14 maja 2009, 15:01
I suggest you use piggyback. We have a really nice Polish product (PC software is in english) called ECUMASTER. This has been used in few mazdas in Poland and i have some experience with it in my 1.8 dohc N/A engine and 1.8 GTX turbo engine.
If you want to use stock ecu you have to extend injectors opening time accordingly to boost pressure. To do this you need signal from map sensor. To fine tune it you can use wideband oxygen sensor. Most affordable kit i know is LC-1 Innovate wideband kit (approx 199$) . ECUMASTER is approx 150$.
Od: 17 mar 2007, 21:04
Auto: RX8
Postprzez Pit » 14 maja 2009, 15:09
armandask napisał(a):Injectors are GTX
Do not play with remaping stock B6 ECU, I'm afraid it is only wasting your time. First, upgrade your fuel pump, stock B6 pump is not good choice for GTX engine with GTX fuel system. Use most popular, Walbro 190 lph/255 lph. Electronic – cheaper way is piggy-back with stock ECU, more expensive, but rather the best – standalone ECU, for example: megasquirt.
Auto: FD3S
Postprzez armandask » 14 maja 2009, 15:25
Thansk everyone, we'll try to solve it somehow :)
Auto: mx-3
Postprzez Fiveopac » 14 maja 2009, 16:07
Or you can start with an FMU 12:1 ;)
Less roof, more fun
CUP 2017 miejsce 3
CUP 2018 miejsce 3
Auto: MX5 NC 2.5T
RX8 R3
Postprzez Cukierek » 14 maja 2009, 18:08
Jaki masz ECU? Od B6T czy B6?
www.gtrproject.pl
Od: 24 kwi 2005, 21:35
Postprzez armandask » 17 maja 2009, 17:45
Few moments of Lithuania MX-3 club Grand meet this weekend :)
http://www.youtube.com/watch?v=sH0ztcp4Ix0
http://www.youtube.com/watch?v=J4aBrWIyQJo
Auto: mx-3
