Haxball – przeglądarkowa gra online w piłkę nożną dla Mazdowiczów
CreaLive napisał(a):lukasz.b napisał(a):http://www.haxball.com/?roomid=6948ced386523041621fece2786eab2e2e619441a967fe8ce7ff648fda9b16fd&pass=1
U mnie nie trybi
U mnei też nie
CreaLive napisał(a):lukasz.b napisał(a):http://www.haxball.comSiw-y napisał(a):Czyli co? sewo spowalnia?
Może za dużo osób czy coś, ale i tak sie gra beznadziejnie powyżej 3 vs 3... Najlepiej jakby tyle os. gralo max a reszta oglada, później zmiana... itd
- Od: 29 sie 2009, 13:10
- Auto: Mazda3 BL Z6 Alu Silver
Była: Mazda 3 2 3 F GT
Siw-y napisał(a):lukasz.b napisał(a):http://www.haxball.com/?roomid=f5f7f390fe768e44232f1cecb5a3645be9ac79be101644fc43f7521de641f4f3&pass=1
nowy link
dupa
zbita
ktoś inny musi, dalej nie trybi
mozna wbijac
- Od: 13 lis 2010, 13:38
- Auto: Mazda 323F
U Łukasza normalnie działało
wiec moze tam wejdziemy
- Auto: Mazda 323F
jesli sa chetni to czemu nie
- Auto: Mazda 323F
I can't connect to any rooms! It gets stuck at the "Connecting to host" phase.
If you're experiencing problems connecting to host then you are one of the unfortunate few people who have evil routers.
The reason you have this problem is because the NAT hole punching tech used to make P2P connections in Flash is not compatible with your network topology. This is not a problem with the game, it is a problem with Flash, there is nothing the dev can do about it.
Players have reported a few ways to solve this problem:
* Forwarding all the UDP ports in the range 1024..65535 (a lot I know, Flash will pick one at random from that range).
* If you are behind two routers enable UPnP in the first one.
* Removing your router from the equation entirely and connect directly to the internet.
* If you are unable to enact the above fixes, don't worry, there are some hosts that you will always be able to connect to, make sure to try every game available. You will be able to connect to at least one of them.
If you find any method to fix this that isn't mentioned in this FAQ please let us know and we'll add it here.
Zastosowałem pierwsze 2 porady (mam 1 router ale i tak dałem enable), ciekawe czy coś pomoże.
Ostatnio edytowano 28 sty 2011, 00:41 przez jaaco, łącznie edytowano 1 raz
Jak zauważyliście w Room List są podane
Nazwy pokoju || Ilość graczy || Hasło[tak/nie] || Państwo || Dystans
Im jest większy dystans między nami tym większe pingi, a jeśli więcej ludzi przy tym to wiadomo – pokazy slajdów. Obrali dziwny sposób działania, może to poprawią.
- Od: 4 wrz 2010, 13:10
- Auto: 323F BJ DiTD 00
Ja mam słabego neta, ale może bedzie śmigać, jak nie to niech ktoś inny postawi i poda linka.
http://www.haxball.com/?roomid=7ce64c51 ... 9d1&pass=1 = closed
Ostatnio edytowano 28 sty 2011, 14:58 przez jaaco, łącznie edytowano 1 raz
1/4 Konin`10-16,41,Kamień Śląski `10 -16,35,Piotrków`10-16,21
Konin`11-16,00
- Od: 1 paź 2008, 18:41
- Auto: 323f BA V6 `98
6 GH 2.0 140km `08
Użytkownicy przeglądający ten dział: Google Adsense [Bot] i 17 gości
