Kamera cofania: Czy można dołożyć?
Where is your boot release button? Inside the car or on boot lid? If inside the car, the extra plug is for switch on the lid. Otherwise I have no idea, but I can check if you provide any plug pictures.
- Od: 14 cze 2006, 01:01
- Auto: 1. Mazda CX60 KH PHEV
2. Mazda 3 BM Skyactiv-D
hi I install the harness and fit perfect, I have inside the cabin trunk release button and in the key control too, works perfect as the camera too, only a free connector that its show in the pictures i add.
can be connect something else in the connector, its like your harness.
thanks darrecki and wojtek.
regards.
regards.
That plug is for boot opener located at lid, next to camera. Having that harness you can always add it in future
European cars do not have boot release switch inside the cabin. Glad we could help.
Chyba jakaś pomyłka w tej informacji.
Kolega założył do sedana wiązkę, która wg powyższego, jest dedykowana do HB.
Gdzie były części zamawiane i ile kosztowały, jeżeli można zapytać?
Czy tylko wpina sie ten zestaw w instalacje i działa czy jeszcze trzeba coś modyfikować?
A. Saloon (sedan)
1. bulb and a back up monitor:
BJT1-67-060, BRM4-67-060B
2. led and a back up camera:
BJV6-67-060, BRM6-67-060B
B. Hatchback
BPN2-67-060, BJG8-67-060A
2. led and a back up monitor:
BPN3-67-060, BJG9-67-060A
thanks darrecki, i appreciate your comments and help as wojtek too.
as my mazda its from japan i think thanks why has the release button inside.
one thing to tell its i ask dealers in mexico and usa and they simply not know what replace harness can help. Im glad that i found this forum and look that the harness you share can be a solution to the people that want to install the rear camera in the sedan.
fux the price for the harness was as describe below
Shipment Details
Part Number
Part Name
Price
Quantity
Total
BHN4-67-060A
HARNESS NO.2 REAR
$41.45
1
$41.45
Subtotal:
$41.45
Shipping (USPS – First Class):
$4.60
Total:
$46.05
Check your order status
Company Information
Quirk Parts,
115 East Howard St
Quincy, Massachusetts, 02169
USA
781-917-1071
support@quirkparts.com
I just retire the original harness and replace with the one that darrecki share BHN4-67-060A
it was plug and play.
hope this help.
regards
Dopisano 11 May 2016, 01:58:
darrecki in your image between the light and the fog light its a small white area what sensor it is or what does do, you have in the front and the rear fascia.
regards.
Shipment Details
Part Number
Part Name
Price
Quantity
Total
BHN4-67-060A
HARNESS NO.2 REAR
$41.45
1
$41.45
Subtotal:
$41.45
$4.60
Total:
$46.05
Company Information
Quirk Parts,
115 East Howard St
USA
781-917-1071
hope this help.
regards
regards.
fux napisał(a):Chyba jakaś pomyłka w tej informacji.
B. Hatchback
Zalozyl BHN4-67-060A, ktorej nie ma na liscie Wojtka.
Jak masz Sedana możesz podejmowac temat, jak HB odpuść – nie wiemy jaka wiązka do niego idzie. Nie ma sie tez co sugerowac rynkiem Amerykanskim, bo jak widac tam nie maja otwierania bagaznika w klapie (aczkolwiek nie wiem czy taki jest w HB). W Sedanie jak widac jest PnP.
mazda3mxli napisał(a):darrecki in your image between the light and the fog light its a small white area what sensor it is or what does do, you have in the front and the rear fascia.
Point the picture please, as I have no idea what you asking for
About where your car is made – when VIN starts with "J" its made in Japan, "3" Mexico.
Boot release switch location depends on the market, not where they are made.
darrecki napisał(a):Zalozyl BHN4-67-060A, ktorej nie ma na liscie Wojtka.
Mam sedana. A więc warto rozważyć zakup i montaż. Dzięki.
EDIT: Wiązka dostępna 4-6 tygodni z Japonii. 380 zł
EDIT: Wszedłem na stronę, aby zamówić. Koszt samej dostawy 126$
Macie pomysł na tańszą dostawę?
Ale kombinujesz...
Masz M3 z Meksyku... i wiązke o numerze BLE3-67-060...
Potrzebujesz wiązki: BJV6-67-060
Jedź do ASO i niech zamówią...
Dopisano 11 maja 2016, o 15:58:
Kamery:
– sedan to: BHN1-67-RC0A
– 5 door to BHN9-67-RC0A
Myślę, że lepsza i tańsza będzie chińska ich odmiana...
Kamery:
Wojtek napisał(a):Ale kombinujesz...
A dlaczego nie BHN4, skoro ma SkyPassion, ja mam odpowiednik SkyPassion i u mnie taka pasuje? Czyżby Mazda miała taki burdel w kablach?
Odpowiedź z Mazdy
Coś w tym jest...
A więc z USA
kamera-178,26$
wiązka-41,45$
fracht-120-180$
RAZEM 339,71=~1.315,70 zł
Cena w PL przy odliczeniu połowy VATu 1.487,00 zł
Cena kamery BHN1-67-RC0A – 1519zł
Wiązka nie zawiera kamery BJV6-67-060 – 270zł nie ma zastosowania w podanym nr VIN.
Zestaw kamery do M3 sdn z oferty akcesoriów Mazdy wraz z wiązką – 1640zł
Coś w tym jest...
A więc z USA
kamera-178,26$
wiązka-41,45$
fracht-120-180$
fux napisał(a):...BJV6-67-060 – 270zł – nie ma zastosowania w podanym nr VIN.
Odpowiedź serwisu Mazdy jest poprawna...
Podana wcześniej wiązka nie ma zastosowania w Twoim numerze VIN, bo Twoje auto nie ma na pokładzie kamery cofania... Mają ją natomiast auta wyposażone w kamerkę, które zostały wyprodukowane w tym samym okresie co Twoje...
Inaczej... takie tam: ten ma a tamten nie ma... i już masz dwie różne wiązki...
darrecki napisał(a):Czyżby Mazda miała taki burdel w kablach?
Nie... Każdy przedział numerów VIN ma różne kable...
darrecki napisał(a):A dlaczego nie BHN4, skoro ma SkyPassion, ja mam odpowiednik SkyPassion i u mnie taka pasuje?
Może pasuje, a może nie... może są inaczej wyprowadzone kable...
Dopisano 11 maja 2016, o 17:35:
mazda3mxli napisał(a):what sensor it is or what does do,
Washer nozzle – headlights
Wojtek napisał(a):darrecki napisał(a):A dlaczego nie BHN4, skoro ma SkyPassion, ja mam odpowiednik SkyPassion i u mnie taka pasuje?
Czyli burdel. Jedna generacja milion kabli.
Bo na różne rynki i gusta klienta. Pamiętasz dla SD? Wystarczy że przycisk do otwierania bagażnika jest w środku i już inna wiązka, do tego halogeny czy ledy. Naprzeglądalem się forum tajlandzkich, rosyjskich, niemieckich i angielskich. Na każdym z nich występowały inne oznaczenia wyglądających identycznie wiązek niestety do swojego nie zidentyfikowalem :/
Jedyne co mi przychodzi do głowy, to podział tych samych wiązek na Japonię i Meksyk. Więc moja teoria głosi, że wszytko jest zdublowane. Do tego dochodzą wariacje z otwieraniem klapy. Daje to 16 (!!) wiązek, po 8 (4 dla Japończyków i 4 dla Meksykańców) oddzielnie dla SD i HB. Do tego dochodzi jeszcze po jednej bezpośrednio do systemu multimedialnego, co daje zawrotną liczbę 18!
Motion napisał(a):...niestety, do swojego nie zidentyfikowalem :/
Podaj numer VIN na PW... zerknę
Każda grupa produkowanych aut ma dwie wiązki... na ledy i na żarówki halogenowe... z kamerą i bez niej... co daje 4 wiązki dla SD i 4 dla HB
Czy są różnice pomiędzy nimi? ... pewnie są...
Mnie podali z USA 56$ z tascaparts
Dopisano 12 maja 2016, 21:54:
Wojtek napisał(a):Motion napisał(a):...niestety, do swojego nie zidentyfikowalem :/
No tu znalazłem taką sciągę ale nie ma pełnych numerów http://wsdemo.laximo.ru/index.php?option=com_guayaquil&view=unit&c=MAZDA201401&vid=697&uid=5186&cid=275&ssd=wid@697~code@Y1~ilfl@5B010F7~iml@ilb~fr@f~_@eFbdElnIq40!&path_id=37624&Itemid=512&lang=pl
Motion napisał(a):Naprzeglądalem się forum tajlandzkich, rosyjskich, niemieckich i angielskich. Na każdym z nich występowały inne oznaczenia wyglądających identycznie wiązek niestety do swojego nie zidentyfikowalem :/
Już znasz...
Jeżeli macie w aucie wiązkę o numerze BJS8-67-060 (żarówki bez kamery cofania), to szukajcie wiązki o numerze BJT1-67-060 (żarówki i kamera cofania)...
