znalazłem na stronie
http://chiptuning.com.au/mazda-cx7-2-2d ... eat-sheet/MAZDA CX7 2.2D (2009 – 2014) DPF REGEN CHEAT SHEET
Cheat Sheet
DPF FORCED REGEN
The following procedure describes how to start DPF forced Regen without the dealer diagnostic tools
1.Make sure the engine is completely warm (important).
2.Remove the dust cap from the plug see in pics below.
3.Bridge the 2 terminals by inserting a wire into each terminal. This provides an earth for the ECU.
4.Start the engine.
5.Press the accelerator to the floor and release 2 times.
6.The engine speed will increase. If not, repeat step 5 making sure the engine is COMPLETELY warm.
7.This process can take 60 mins.
8.When the engine returns to idle Let engine run for 3 min before turning off.
9.Remove the wire from the 2 pin plug and replace dust cap.
To stop the DPF Regen process press the clutch down or simply remove the wire bridge from 2 pin plug.
Let it run for 3 min before turning off.
IMPORTANT: Must be done outdoors.
How to reset DPF Counters and DPF Light after DPF Regen process.
1.Ignition to position ON.
2.Make sure the engine is warmed up (important).
3.Remove the dust cap from the plug see in above pics.
4.Bridge the 2 terminals by inserting a wire into each terminal. This provides an earth for the ECU.
5.Press the accelerator to the floor and release 5 times.
6.Remove the wire from the 2 pin plug and replace dust cap.
How to do Counter Reset after oil change
  zda CX7 DPF Regen
Clean out the oil pick-up in the sump before it kills your engine
	This is what it looks like
when the oil pick up is blocked and kills your engine.
	This is a nice new one.
This happens when the oil gets polluted from bad diesel when cleaning the DPF.
It can also happen if you use the wrong engine oil.
Remember to check and clean it once in a while.
