Procedura kasowania błędów ABS:
1) DTCs Clearing Procedure
Using SST (WDS or equivalent)
1. After repairs have been made, perform the DTCs retrieving procedure.
2. Erase DTC by WDS or equivalent.
3. Ensure that the customer’s concern has been resolved.
Note
• After repairing the ABS wheel-speed sensor or replacing ABS HU/CM, the ABS and/or BRAKE system
warning light may not go off when ignition key is turned ON. In this case, start engine and drive the vehicle
at a speed of more than 10 km/h {6.2 mph} until the ABS and/or BRAKE system warning light goes off.
2)
Without using SST (WDS or equivalent)Caution
• Connecting the wrong DLC terminal may possibly cause a malfunction. Carefully connect the
specified terminal only.
1. Connect the TBS terminal at the DLC to body
ground using a jumper wire.
2. Turn the ignition key to ON (engine OFF).
3. Output all stored DTCs.
4. After verifying that the first code is repeated,
depress the brake pedal 10 times at intervals of
less than 1 second.
5. Turn the ignition key to OFF and disconnect the
jumper wire.
6. Turn the ignition key to ON and verify the ABS
warning light turns off after 3 seconds.
Chodzi zapewne o procedurę nr. 2
