Może wrzucę tak na przyszłość opis błędów poduszek:
Wynika z tego że błąd 1 to sam sterownik, a 22 to lewy sensor (czyli ten przy pasie bezpieczeństwa)
1 : (SRS control module) : Wiring, open/short circuit, SRS control module
2 : (SRS control module) : SRS control module
3 : (Supply voltage) : Wiring, fuses, SRS control module
6 : (Driver's airbag) : Wiring, open/short circuit, driver's airbag, spiral cable, SRS control module
7 : (Passenger's airbag) : Wiring, open/short circuit, passenger's airbag, SRS control module
11 : (Pyrotechnic pretensioners, driver's side) : Wiring, open/short circuit, pyrotechnic pretensioner, SRS control module
12 : (Pyrotechnic pretensioners, passenger's side) : Wiring, open/short circuit, pyrotechnic pretensioner, SRS control module
22 : (Side crash sensor, driver's side) : Wiring, open/short circuit, crash sensor, SRS control module
25 : (Side crash sensor, driver's side) : Wiring, open/short circuit, crash sensor, SRS control module
26 : (Side airbag, driver's side) : Wiring, open/short circuit, side airbag, SRS control module
32 : (Side crash sensor, passenger's side) : Wiring, open/short circuit, crash sensor, SRS control module
35 : (Side crash sensor, passenger's side) : Wiring, open/short circuit, crash sensor, SRS control module
37 : (Side airbag, passenger's side) : Wiring, open/short circuit, side airbag, SRS control module
44 : (Passenger's seat pressure sensor) : Wiring, short circuit, seat pressure sensor, SRS control module
45 : (Passenger's seat pressure sensor) : Wiring, open circuit, seat pressure sensor, SRS control module
46 : (Deactivation warning lamp) : Wiring, open/short circuit, warning lamp, fuses, SRS control module
47 : (Passenger's seat pressure sensor) : Seat pressure sensor
48 : (Passenger's seat pressure sensor) : Seat pressure sensor
91 : (SRS warning lamp) : Wiring, open/short circuit, warning lamp, fuses, SRS control module
air bag-swieci sie kontrolka
