http://www.cdn.dk/mazda6/How I do it:
1. Change oil and oil filter.
2. Warm up the car, take it for a drive.
3. Clean the DPF. takes about half an hour.
4. Reset for oil change.
5. Reset the DPF.
6. Calibrate the injectors.
7. Finish.
How to start DPF cleaning process
VERY IMPORTANT: Do only this outdoors with 5m free behind
the exhaust and with the hood open.
1. Make sure the engine is warmed up (important).
2. Start the engine.
3. Connect the pin in the red circle to earth (chassis).
4. Press the accelerator to the floor and release 2 times.
5. The engine speed increases, if not got to (2).
6. This process can take 60 min and is very hard on the battery.
7. When the engine goes to idle remove the wire to chassis.
8. Let it run for 3 min before turning off.
To stop the cleaning process press the clutch down and put in 1'st gear and hold
until it idles or disconnect the wire. Let it run for 3 min before turning off.
How to reset DPF after cleaning process
1. Ignition to position on.
2. Connect the pin in the red circle to earth (chassis).
3. Press the accelerator to the floor and release 2 times.
4. Ignition to position off.
5. Remove the wire between the connector and chassis.
How to reset after an oil change
3. Press the accelerator to the floor and realese 5 times.
4. The glow plug light flashes 5 times when resetting is complete.
5. Ignition to position off.
6. Remove the wire between the connector and chassis.
How to calibrate the injectors
3. Connect the pin in the red circle 5 times within 5 sec. to earth (chassis).
4. The glow plug light flashes 5 times when the calibration is finish (< 3 min).
5. If not got to (2).
The injector calibration can be a bit tricky to get right the first time so don't panic
just keep on trying.
How to reset the auto wipers
1. Ignition to position off – wipers on OFF.
2. Turn wipers to AUTO position.
3. Turn ignition to position ON – Within 10 seconds – switch from AUTO to OFF 5
times – 1 second off 1 second auto.
4. The wipers will cycle once to register new initialization.
I have made a wire with a switch so I can connect to the pin and minus on battery
and sit in the car an do every thing.
