fakowanie obrotów
Mazda 323 1980–1995
Postprzez kafar » 7 mar 2015, 18:33
witam mam mazde 323 1,5 96 jest zagazowana jak chodzi na wolnych obrotach strasznie faluja obroty ktos moze powiedziec jakie przyczyny moga byc???
Od: 7 mar 2015, 18:09
Auto: mazda 323f 1,5 1996
Postprzez affectgoujon » 14 cze 2024, 05:05
The fluctuating idle in your Mazda 323 could be caused by:
1. Vacuum leaks
2. Dirty or faulty Idle Air Control Valve (IACV)
3. Faulty Throttle Position Sensor (TPS)
4. Dirty or faulty Mass Air Flow Sensor (MAF)
5. Dirty fuel injectors
6. EGR valve problems
7. Ignition system issues (spark plugs, ignition coils, etc.)
8. Fuel pressure issues
9. Dirty air filter
10. Engine Control Unit (ECU) problems
Check these components to diagnose and fix the issue. If the issue persists after checking these common causes, it might be a good idea to take your car to a professional mechanic for a more thorough diagnosis.
Od: 14 cze 2024, 05:01
Auto: Ferrari 296 GTS – The new 120° V6 engine and plug-in hybrid electric drive (PHEV) electric motor
