MX-3 1.6 TURBO
PostNapisane: 14 maja 2009, 06:00
przez armandask
Helow,
in our mx-3 club we have a mx-3 1.6 turbo project (GTX). Now main problems are with stock ecu... Do anybody know what to do with it?
some pics:
http://forum.mx-3.lt/viewtopic.php?f=20&t=1269&start=60
Thanks.
Re: MX-3 1.6 TURBO
PostNapisane: 14 maja 2009, 08:03
przez Pit
armandask napisał(a):... main problems are with stock ecu
Please try to explain us those problems.
PostNapisane: 14 maja 2009, 08:32
przez Fiveopac
Throw away ecu. Install megasquirt :)
Re: MX-3 1.6 TURBO
PostNapisane: 14 maja 2009, 10:19
przez armandask
The fuel mixture too rich and too lean, depends on RPM's
Re: MX-3 1.6 TURBO
PostNapisane: 14 maja 2009, 10:31
przez Pit
armandask napisał(a):The fuel mixture too rich and too lean, depends on RPM's
You can use FMU at this moment, and correct AFR with some kind of piggy-back. But, the best way for you will be...
Fiveopac napisał(a):Throw away ecu. Install megasquirt :)
PostNapisane: 14 maja 2009, 10:42
przez Quaki
Did you change the injectors or the pressure on the fuel rail if yes it is normal problem there are 3 ways to resolve your problem
1. remapping orginal ecu
2.piggyback
3. stand alone like mentioned by Fiveopac megasquirt
Bets regards
PostNapisane: 14 maja 2009, 12:09
przez armandask
Quaki napisał(a):Did you change the injectors or the pressure on the fuel rail if yes it is normal problem there are 3 ways to resolve your problem
2.piggyback
Bets regards
Injectors are GTX
Fuel pomp stock mx-3 (1,6 dohc)
About remapping stock ecu... Do you have that binnary file? :) (like i did with my klze)
PostNapisane: 14 maja 2009, 13:24
przez Quaki
So you have stock ecu from ? GTX or from mx-3 (from what engine you have ecu)
I,m afraid that is not so simple like with the kl engine you if you want to remapp yor ecu you will have to do it yourself by chnaging the code of this ecu (or find someone who is able to do this and have hardware to do this)
Beszt regards
PostNapisane: 14 maja 2009, 14:01
przez jackkpl
I suggest you use piggyback. We have a really nice Polish product (PC software is in english) called ECUMASTER. This has been used in few mazdas in Poland and i have some experience with it in my 1.8 dohc N/A engine and 1.8 GTX turbo engine.
If you want to use stock ecu you have to extend injectors opening time accordingly to boost pressure. To do this you need signal from map sensor. To fine tune it you can use wideband oxygen sensor. Most affordable kit i know is LC-1 Innovate wideband kit (approx 199$) . ECUMASTER is approx 150$.
PostNapisane: 14 maja 2009, 14:09
przez Pit
armandask napisał(a):Injectors are GTX
Do not play with remaping stock B6 ECU, I'm afraid it is only wasting your time. First, upgrade your fuel pump, stock B6 pump is not good choice for GTX engine with GTX fuel system. Use most popular, Walbro 190 lph/255 lph. Electronic – cheaper way is piggy-back with stock ECU, more expensive, but rather the best – standalone ECU, for example: megasquirt.
PostNapisane: 14 maja 2009, 14:25
przez armandask
Thansk everyone, we'll try to solve it somehow :)
PostNapisane: 14 maja 2009, 15:07
przez Fiveopac
Or you can start with an FMU 12:1 ;)
PostNapisane: 14 maja 2009, 17:08
przez Cukierek
Jaki masz ECU? Od B6T czy B6?
PostNapisane: 17 maja 2009, 16:45
przez armandask
Few moments of Lithuania MX-3 club Grand meet this weekend :)
http://www.youtube.com/watch?v=sH0ztcp4Ix0
http://www.youtube.com/watch?v=J4aBrWIyQJo
